8/3/2021 2:37 PM | |
Joined: 1/13/2021 Last visit: 4/5/2024 Posts: 64 Rating:
Hello oguzk1907 If you work with Microsoft Visual Studio you can go to Tools ->NuGet Package Manager->Manage Nuget Package For Solution and In the browse tab Search for the keyword S7netplus and install it. This will add the library to your references, and you can use the "using" command to add it to your program and use its classes. It should be noted that to use this library, you must enable the "permit access with PUT/GET communication from remote partner" option in the "Protection and Security" section. I have attached the documentation related to the library to this message I hope it is useful AttachmentDocumentation.pdf (853 Downloads) |
8/3/2021 2:57 PM | |
Posts: 11 Rating:
Thank you so much. I found it and I am trying to implement this library. |
