3/24/2020 9:32 PM | |
Joined: 4/28/2015 Last visit: 9/11/2024 Posts: 44 Rating:
It would seem that the SinuTrain product would suit your needs. The basic version does not require a license. The software can be downloaded from https://new.siemens.com/global/en/markets/machinebuilding/machine-tools/cnc4you/sinutrain-uebersicht/v4-8.html HTH, SteveA |
3/26/2020 9:24 AM | |
Joined: 2/28/2020 Last visit: 9/18/2023 Posts: 20 Rating:
Hello. Thanks for the link. I would like to receive an automatic check of the user program: I set the initial values of R-variables several times, substitute the user program, and then check the R-variable. The user should get an answer whether his program is true or not without my participation. example: R3 = (R1 + R2) * 2 - true program R3 = R1 + R2 * 2 - the program is wrong This is just an example, a program can be more complicated, with IF, FOR, WHILE, and so on.
