7/28/2012 3:12 PM | |
Joined: 1/28/2009 Last visit: 5/20/2024 Posts: 6840 Rating: (1359) |
Hello, Chapter one "Organization Blocks" will give you very detailed explanation of OBs you asked and all their parameters described thoroughly. System Software for S7-300/400 System and Standard Functions Volume 1 and Volume 2 To master how to use them efficiently ,I suggest reading each case carefully,test your findings,search the forum for answer of your problems and finally ask here if they are not solved. Best regards, Hamid Hosseini |
