6/15/2011 7:37 AM | |
Joined: 4/22/2010 Last visit: 6/5/2024 Posts: 82 Rating:
Hi Experts, What is the proper Profibus Connector Terminating Resistor settings on bus ring topology? Please see attached file for your reference... We have already tried the two available options (turning on and off the terminating resistor of the profibus connector), still the network works properly. It seems that it has no difference whether you turn on or turn off the terminating resistor of the Profibus connector on this particular case. Hope you can help me with this.. Thanks and best regards, lordgalen Attachmentring topology.pdf (626 Downloads) |
6/15/2011 7:46 AM | |
Joined: 3/21/2006 Last visit: 3/30/2025 Posts: 10239 Rating:
Should be ON. Instructions for the permanent termination of a bus segment |
6/15/2011 7:51 AM | |
Posts: 1064 Rating:
The last one in the line should be on .easy rule of thumb one wire on |
