4/2/2012 10:28 AM | |
Posts: 16 Rating:
Hi all, opening ProSave and ProTool I get the "XML parser not foud" error. I cannot start ProSave at all, while I'm able to work with ProTool. I have already tried to uninstall/reinstall either ProSave and the MS XML parser but no effect. Please find attached a pdf with errors screenshot Any help would be appreciated AttachmentParser.pdf (198 Downloads) |
4/3/2012 12:31 PM | |
Posts: 3037 Rating:
Hello, Which operating system do you use? Which versions of SIMATIC ProTool/Lite, SIMATIC ProTool and SIMATIC ProTool/Pro are compatible with which Windows operating systems? Tweety |
4/3/2012 2:50 PM | |
Posts: 16 Rating:
WinXP Professional. All the softwares used to work fine until now |
4/4/2012 10:12 AM | |
Posts: 3037 Rating:
Hello, Which version of ProTool do you use exactly? Which version of Windows XP do you use exactly? Tweety |
4/4/2012 10:40 AM | |
Posts: 16 Rating:
Protool V6.0 SP3 Win XP Professional SP3 BTW, ProTool is working despite the error. The main problem is ProSave (i am not able to update firmwares etc..) |
4/4/2012 11:12 AM | |
Posts: 3037 Rating:
Hello, You can test this version of Prosave. It work fine on my computer. Service Tool ProSave V7.4.4 Tweety |
