3/3/2020 9:39 AM | |
Joined: 4/17/2009 Last visit: 10/23/2024 Posts: 304 Rating: (57)
Hi saleh, using TIA Portal + Safety Integrated provides failsafe timer elements like TP (impulse), TON(switch-on delaying) and TOF(switch-off delaying). With those timer blocks you can realize your requested timer water pump application. If you have an application with only one safety function, you can for example use a safety relay like 3SK. Here you can find more informations about it: https://new.siemens.com/global/en/products/automation/industrial-controls/sirius/sirius-monitor/3sk-safety-relays.html If you need more functionality, you can use a S1200F/1500F application with corresponding output modules. If you need more concept ideas, you can find some at the following link: https://new.siemens.com/global/de/produkte/automatisierung/themenfelder/safety-integrated.html If you have chosen your products, you verify them with the Safety Evaluation Tool. For that you have to define a safety function (detection --> logic --> reaction) Best regards SET Team |
SE Support |
