3/4/2011 2:57 PM | |
Joined: 5/28/2008 Last visit: 12/8/2015 Posts: 901 Rating: (136) |
Hello KGI, thats not possible and will not be supported from siemens. regards Manfred |
4/4/2011 9:11 AM | |
Posts: 327 Rating: (28) |
Greetings Virtualization tools (I've been using VMware Player) should be able to access RS-232 port without problem. Best regards
6/24/2012 8:07 AM | |
Joined: 5/28/2008 Last visit: 6/27/2024 Posts: 4510 Rating: (837) |
Hello, The most trusted way to know compatibility of Siemens software isCompatibility Tool. You can check compatibility between Siemens software and MS OS. And I am sorry to tell that Windows 7 doesn't support any version of Protool. Hope this helps.
Ayman Elotaify |
4/3/2013 4:16 AM | |
Joined: 9/28/2011 Last visit: 3/2/2024 Posts: 4 Rating: (0) |
I am using protool without any problem on Windows 7 32 bit with serial port on board on Toshiba Tecra model laptop. |
4/3/2013 9:13 AM | |
Which versions of SIMATIC ProTool/Lite, SIMATIC ProTool and SIMATIC ProTool/Pro are compatible with which Windows operating systems? |
Ayman Elotaify |
