5/2/2015 9:36 AM | |
Posts: 2 Rating:
Hi I have a problem with my PCS7. when I want to open WinCC in my PCS7 it was properly run. but when I want to go runtime mode I encounter with a license error. but I installed all of my required license properly. my license log: 05/02/2015 10:10:56 InitLicense CS | AppName = DMAso:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC | 05/02/2015 10:10:59 InitLicense CS | AppName = AppCS:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC | 05/02/2015 10:10:59 InitLicense ED | AppName = AppEd:Mcp | CycleCheck = own | NameForMessageBox = | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC | 05/02/2015 10:11:40 InitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC | 05/02/2015 10:11:41 InitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC | Relevant Limit = 0000000512 | 05/02/2015 10:11:41 Control Center - Demo Mode Runtime enabled - 05/02/2015 10:11:41 NoLicense RT | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC | Exists = Yes | Limit Exceeded = No | Emergency License = No | 05/02/2015 10:22:01 ExitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC | 05/02/2015 10:22:01 ExitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC | my license_info.log: 02.05.2015 10:09:35 License_Info start ----------------------------------------------------------------------- 02.05.2015 10:09:36 Is PCS7 project -> PO Licensing 02.05.2015 10:09:36 PO Licensing Mode -> POs:0 Tags:0 02.05.2015 10:11:41 ================DM RTLimit======================= 02.05.2015 10:11:41 Limit.RetVal: 0 02.05.2015 10:11:41 Date: (null) 02.05.2015 10:11:41 Time: (null) 02.05.2015 10:11:41 project: \\MRT-530BA7F5980\WinCC_Project_OS(1)_1\ 02.05.2015 10:11:41 POs in the project: 0 02.05.2015 10:11:41 All Tags in the project: 0 02.05.2015 10:11:41 Limit POs in the Licence: -1 (Second criteria: Limit_Tags = Limit_POs * 90 (=-90) > All tags (=0) !!!) 02.05.2015 10:11:41 ================DM RTLimit======================= 02.05.2015 10:11:41 No runtime licence: Type:AppRT:Mcp Key:SIFLPCS7T20701 -> Activating demo mode also I attached a file include some picture that show you my installed license. thank you.
Attachmentlicense problem Pic.docx (87 Downloads) |
5/4/2015 9:47 AM | |
Posts: 46 Rating:
Hi, have you checked ALM already? There is a function called "Missing Licences". What is the result of that?
regards |
5/4/2015 12:38 PM | |
Posts: 567 Rating:
Hi, did you check the license key. Maybe the this key is defect. |
