3/14/2013 2:58 PM | |
Posts: 48 Rating: (1) |
Dear KSN, first: i didnot find K040 in the parameters Description of the drive parameters. so i attached you the actual parameters uploaded from drive after modifed the parameters you mentioned before. in the same time i run the motor and the drive displayed alarm (F042). if you please to check the attached parameters of the drive to fix this problem and send me back. thanks AttachmentSIMOREG DC MASTER_tmp.zip (219 Downloads) |
3/14/2013 3:14 PM | |
Joined: 8/25/2006 Last visit: 9/18/2024 Posts: 2209 Rating: (278) |
Your parameter list does not contain K040. What is the value of F042? Look at themanualand check the possible reasons of F042:
3/14/2013 5:21 PM | |
Have you made an optimization run for speed controller (P051=26)? |
