9/16/2015 3:09 PM | |
Posts: 3609 Rating: (29) |
Import of a Technical Question of the user Adel_24
9/16/2015 4:07 PM | |
Joined: 1/28/2009 Last visit: 8/26/2024 Posts: 6846 Rating: (1365) |
Hello Adel_24,
The following link will provide example blocks for WinCC (TIA Portal) and STEP 7 (TIA Portal) for S7-1200 and S7-1500 with SCL .You can find blocks and faceplates for wide range of devices such as pumps, valves and a PID regulator: Example Blocks for WinCC (TIA Portal) and STEP 7 (TIA Portal) for S7-1200 and S7-1500 with SCLI am sure they will be great help if you read the related manuals carefully and try to develop your own application.For TIA Portal, search the SIOS and you will find plenty of sample software applications. I hope this helps, hdhosseini |
