3/18/2024 11:35 AM | |
Joined: 2/11/2020 Last visit: 7/30/2024 Posts: 7 Rating:
Hi Hazard The main CPU (A) is 1515F and my second one (C) is 1510SP. Best regards |
3/19/2024 9:32 AM | |
Joined: 3/11/2019 Last visit: 8/20/2024 Posts: 1555 Rating:
Hi, I assume you use the same connection name "S7_Connection_1" in both blocks. Click on the three dots behind the name and add a new seperate connection for the other instance. As an alternative you can create a new connection directly in hw config, as shown in this FAQ. How you configure a connection in the TIA Portal?regards sancruz |
Feedback appreciated, please rate |
3/19/2024 10:06 AM | |
Hi Thanks for the advice! Can i download this without putting the plc in stop? best regards |
