5/29/2021 8:01 PM | |
Joined: 5/6/2010 Last visit: 5/19/2024 Posts: 1965 Rating: (274)
Hello, it's not possible to output 0..15 V at the PWM output of the 1200. One way to solve your problem is that you use a solid-state-relay to switch your 15 V with the PWM-signal from the 1200. You can use e.g. Solid-state relay module - PLC-OPT- 24DC/ 48DC/500/W - 2900378 or Solid-state relay module - PLC-OPT- 24DC/ 24DC/10/R - 2900398 regards |
