7/30/2022 2:26 PM | |
Joined: 7/8/2021 Last visit: 12/30/2023 Posts: 1 Rating: (0) |
Hello, Please Help... I'm using CPU 1511-1PN and DQ 8x24VDC/2A HF Module. My Application is to drive BLDC Motor through one small drive. In the DQ Module there is 2 PWM Channels Namely CH0 and CH4. I Configured this as PWM Channel from properties also assigned required DUTY CYCLE as per datasheet of DQ module. But I'm unable to get Output from CH0 or CH4 can anyone Please Help to solve this query. Followings are screenshots for reference. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/01/2022 10:38:14New subject after splitting |
