9/5/2023 1:21 PM | |
Joined: 7/19/2022 Last visit: 7/24/2024 Posts: 378 Rating:
Hello AutoGen_1348261, The problem is that CPUs with Rly output cannot be used for PWM. You would need a DQ card to be able to have PWM outputs |
