3/31/2020 10:29 AM | |
Posts: 75 Rating: (0) |
Hello, Long time I have worked with SIMATIC Step7 manager. Now I need start working with TIA portal. 1) Is possible with higher version open projects made in lower version? If i buy tia portal licence v16 is possible opening projects v14 or v15? 3) What's difference between Step7 basic and professional? 4) How to get siemens v90 drives library in TIA portal? Please give me some basic instructions. Thanks! Best regards. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/31/2020 12:09:10New subject after splitting |
3/31/2020 11:46 AM | |||||||||||
Joined: 5/12/2006 Last visit: 5/14/2024 Posts: 22251 Rating: (2985)
Hi, latest version is V16 UPD1. Contact Siemens Sales department next you or use SIEMENS MALL if you registered there. the minmum system configuration listed in the delivery nodes of the TIA Portal Version for V16 : https://support.industry.siemens.com/cs/ww/en/view/109771628
