10/9/2023 8:36 PM | |
Joined: 12/27/2006 Last visit: 7/7/2024 Posts: 1197 Rating:
Most VFD you can set with Di on the VFD. PE: IF Di1 = ON Run 15 Hz, IF Di2 = ON Run 50 Hz You need a LOGO with a analog input and 2 Digital Outputs What kind of sensor for the light you use? In the attachment an example, AS AN EXAMPLE AttachmentLight.zip (265 Downloads) |
10/9/2023 11:16 PM | |
Joined: 12/18/2014 Last visit: 8/15/2024 Posts: 33570 Rating:
Use this by using AM2 AQ module. |
