4/28/2017 10:17 AM | |
Posts: 84 Rating: (8) |
Hi, Try to display what you get with the fso.Dir (filename) command as a system alarm for example. Regards |
4/28/2017 4:44 PM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating: (121) |
Hey, look to this faq => https://support.industry.siemens.com/cs/ww/en/view/26107211 I mean, this could be a solution for you.... |
5/5/2017 10:34 AM | |
Joined: 8/3/2009 Last visit: 5/6/2024 Posts: 12882 Rating: (1645)
Hello chm357 Be sure that you use the correct script functions. If you are using a WinCC advanced Runtime OR you run simulation of you comfport PAnel only the syntax of this FAQ works: https://support.industry.siemens.com/cs/ww/en/view/106501825 but on the Comfort Panel in Runtime only this Syntax works!!!: https://support.industry.siemens.com/cs/ww/en/view/59604194 there are different obects in Windows and WinCE to use. Bye Murof |
