5/3/2014 3:17 PM | |
Posts: 1 Rating: (0) |
HiENG.ABDUL I had the same problem, it seems you need to change the words (register) order. when the analog valuse mapped to MODBUS registers in some systems MSB and LSB are exchanged and this can lead to confusion. I make a block as attached and the problem solved. Regards Akbar |
5/4/2014 7:13 AM | |
Posts: 34 Rating: (0) |
Thanks for your support |
