1/20/2014 10:56 PM | |
Posts: 6 Rating:
Thanks jumo Sorry on the previous post, I was not quite sure of what I was really looking for. What Iam really looking for is to read values from Excel and store it in PLC Data Block and write Data Block values to Excel every min. There's a mode selection auto/manual on the HMI Screen. Once I'm in Auto mode, I want the above function (i.e. to read/write) to be executed every minute. I'm using TIA Portal v12, I am not able to find a way to create a global action like normal Wincc Explorer. I only see an option to create VB Functions. Please advise. I've attached the excel file (pdf version) that is being updated every minute for reference. AttachmentSCADA-EMS Interface V6.pdf (2017 Downloads) |
3/14/2014 2:04 PM | |
Posts: 1299 Rating:
Hello, maybe this post in wincc forum may help you. didn't try it in tia portal but basically you try to change something in windows so it should be independent of wincc version... K!ke |
12/14/2015 4:14 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4769 Rating:
New question published by KrisMaesGent is split to a separate thread with the subject WinCC V13 advanced, save xls file as a pdf. Best regards |
