1/12/2021 8:31 PM | |
Joined: 9/27/2006 Last visit: 5/4/2024 Posts: 12257 Rating: (2666) |
Hello Binot Kumar; How did you set the RTC in the S7-226 (the S7-226CN is the same as a S&-2226, except that the Microwin computer regional and language settings are set to Chinese)? Have you followed the suggestions in this document? - How can you read out the S7-200 CPU clock and output the values in integer format and how can you set the S7-200 clock with default integer values? https://support.industry.siemens.com/cs/ww/en/view/19294366 Have you opened the menu PLC in Microwin, to make sure the TIME of Day Clock has been started. If yau have done all this and you still have problems with the RTC, please describe in more details what happens to the RTC and when it happens.No error messages? hope this helps, Daniel Chartier |
