9/8/2016 9:42 PM | |
Posts: 439 Rating: (108) |
You can use "SetPLCMode" to STOP on "Press" event, use "SetPLCMode" to RUN on "Release" event and call the button "Reset PLC" |
9/9/2016 11:51 AM | |
Posts: 5225 Rating: (1188)
Indeed an ugly problem. May I suggest.. do the solution you have in mind. Maybe the Forum can bump heads together for an "automatic" recovery.... just maybe. Else create a formal support request with Siemens: ... just please be patient and courteous with the support guy that answers you call. The more detail you can give, the better. Probably on the 2nd reply will start being helpful. Go well. |
