4/12/2011 4:17 PM | |
Joined: 7/2/2008 Last visit: 8/26/2024 Posts: 928 Rating:
Hello Automation Way, It depends on your final element. If your actuators can be operated with the rated output current of your module's channel then you can use MTA without relays. If your final element requires different potential or higher current or even the same potential, same current but requires isolation then you have to use MTA with relays. Take very good care of MTA selection. Best regards H-H |
