5/17/2019 9:35 PM | |
Joined: 9/27/2006 Last visit: 7/14/2024 Posts: 12268 Rating: (2675)
Hello Grzesiuk; Is it mandatory to do this in STL? in that case you could base yourself on the code provided by Piotr.m in the following discussion: Create logic programming- FIFO and LIFO However, instructions for manipulating tables are available in Step 7 classic, in the TI-S7 converting library. Look at FC85 FIFO, for example, and study the online help for that function to see how to format you table (DB) fso FC 85 will function properly. Fifo for S7-300 https://support.industry.siemens.com/tf/ww/en/posts/fifo-for-s7-300/49258/?page=0&pageSize=10 Hope this helps, |
