5/3/2019 3:39 PM | |
Joined: 8/3/2009 Last visit: 4/26/2024 Posts: 12869 Rating: (1641)
Hello if you cannot do an online loading then you only can do a full load In this case you can do it in the same way as in the Classic WinCC: https://support.industry.siemens.com/cs/ww/en/view/24193864 But I would try it with a Backup, because its not officially released from siemens for TIA Portal but it should work also. Bye Murof |
