6/9/2015 9:27 AM | |
hi SATYA, what about to use the SFC51 "RDSYSST" (read system status) and send the Information via your already existing connections. See this manual chapter 13 to see how to use this function: System Software for S7-300/400 System and Standard Functions Volume 1 and Volume 2to check the connection works correctly a simple toggle bit will be the easiest solution.hope this helps,regards, |
FCK WAR! |
6/9/2015 11:39 AM | |
Posts: 94 Rating:
Hi MOPs04 , Thanks for your support . Is it possible to read all remote CPU status from Master CPU with the help of SFC51 . |
