8/21/2019 10:56 PM | |
Posts: 21 Rating: (0) |
Hello, have you ever tried to connect a PC with TIA Portal to another PC onsite(without TIA) connected to an S7 1500? OpenVPN? something like that? Thank you!! |
8/21/2019 11:04 PM | |
Joined: 9/27/2006 Last visit: 9/16/2024 Posts: 12282 Rating: (2684) |
Hello Mike; Possibly the contebts of this Application Example can be useful to you: Overview: Secure Remote Access with VPN https://support.industry.siemens.com/cs/us/en/view/26662448 Hope this helps, Daniel Chartier AttachmentSiemens Security Integrated Portfolio in virtual private networks (VPN).jpg (848 Downloads) |
8/29/2019 1:05 PM | |
Joined: 8/3/2009 Last visit: 9/16/2024 Posts: 13694 Rating: (1726) |
Hello If there is no solution then you can also use the siemens automation tool in the PC nearby the PLC: https://support.industry.siemens.com/cs/de/en/view/98161300 or you use a router or a gateway to get access Bye Murof |
8/29/2019 1:15 PM | |
Joined: 5/12/2006 Last visit: 9/16/2024 Posts: 22356 Rating: (3009)
Hello, or you use SIEMENS TIA Cloud Connector https://support.industry.siemens.com/cs/ww/en/view/109747305 Regards Christoph |
