4/25/2014 12:02 PM | |
Joined: 10/11/2006 Last visit: 9/9/2024 Posts: 5902 Rating: (803) |
Hello, yes,it is possible tochange motor data on SMI. Nevertheless it is very tricky. You should give SMI to SIEMENS Service Center: http://support.automation.siemens.com/WW/view/en/16610214 |
With best regards, |
4/25/2014 1:44 PM | |
Posts: 2 Rating: (0) |
Dear TechTeam Far as I know it is very easy if you have CU 320 module and STARTER SW. Also siemens has service SMI for this matter. |
4/25/2014 2:14 PM | |
Hello, then you know more than I do! Try out following document with the link: http://support.automation.siemens.com/WW/view/de/91198165 I would recommend you to contactthe service center regarding password of required access level and bin-files. Good luck! |
