5/16/2015 8:48 AM | |
Joined: 5/14/2015 Last visit: 1/19/2024 Posts: 15 Rating:
hello . depend on the folloing link : https://support.industry.siemens.com/cs/document/56600676?dti=0&lc=en-WW i am trying to use these program but i need to modify sometings like the folloing : in my program PLC , i have FC2 and FC3 using in my process , so i make replace FC2 by other name function like FC200 i the attachment photo refare to the error in OB1. HOW can i solve these problem please.
Last edited by: Min_Moderator at: 5/18/2015 2:18:55 PMNew subject after splitting |
5/16/2015 9:04 AM | |
Posts: 5225 Rating:
Have you changed the block number and compiled before calling the blocks? You could maybe also have a look at [LINK] dated [5/6/2015 5:04 PM] for some alternate base code. Greetings. |
5/18/2015 9:40 AM | |
hello . also depend on https://support.industry.siemens.com/cs/document/56600676?dti=0&lc=en-WW i want to do these algorithm for about 33 64bit signals . how can i do that ? is the following correct : - modify DB and adding all signals. - then on OB1 call Function for all signals . is that correct ? please help |
