12/1/2013 4:54 PM | |
Joined: 9/27/2006 Last visit: 4/30/2024 Posts: 12257 Rating: (2666)
Hello Ariya man; If you have the part number of the original module, it is easy to use the Product Support pages to find the "Successor" modules. For your CPU, your start page will be here: http://support.automation.siemens.com/WW/view/en/4069055 Simply follow the successor product tab until you find the 416-2XN05 model which is a direct replacement. So it should be possible to use the new CPU instead of the old one, or to configure it as the older part number in the original configuration. See the attached picture to give you an illustration. Hope this helps, Daniel Chartier |
12/2/2013 6:47 AM | |
Posts: 90 Rating: (7) |
Thank you Daniel! it was very detailed and helped a lot! |
