2/19/2015 5:27 PM | |
Joined: 8/3/2009 Last visit: 7/19/2024 Posts: 13341 Rating:
Hello dkor usually it is very save to do a Backup/restore. You can use the following instructions. There is everything explained which you should know: https://support.industry.siemens.com/cs/ww/en/view/28928853 I hope it helps Bye Murof |
