3/9/2009 9:30 PM | |
Posts: 271 Rating:
Hello Vijay, It is not clear what the encoder designations you mention are (e.g., TTL encoder, Sine encoder, SSI encoder, incremental (relative) or absolute, etc.). Here is a TTL encoder document: http://cache.automation.siemens.com/dnl/DQ3MjU1AAAA_19980380_HB/Beibl_ink_0402.pdf Here is an EnDat/SSI document: http://cache.automation.siemens.com/dnl/DM/DMyODIyOQAA_19979721_HB/Beibl_SSI_EnDat_0806.pdf Hope this helps... |
