4/30/2008 7:19 AM | |
Posts: 487 Rating:
You could try DOSBOX Its a dos emulator used for games but also support the serial port
On your quick question : We use a siemens rack with a mirrored array and as a test I pulled one HD out while running , put it back .... waited ( about an hour) to rebuild and then pulled out the other drive ... and winCC kept running no complaints about licenses...To be honest when we did the test I did not think about the licenses but to my knowledge the mirroring is done on bit level Eric |
Last edited by: aikona at: 4/30/2008 7:21 AMLast edited by: aikona at: 4/30/2008 7:20 AM |
