4/18/2019 12:36 PM | |
Joined: 1/28/2009 Last visit: 4/26/2024 Posts: 6838 Rating: (1359)
Agreed, you can easily make a similar concept available in your pump/motor control block.You can apply an external pulse for each second/minute/hour count an internal value in case of a positive edge, keep the value and make proper conversions. You also have the chance to use ready to use FBs for STEP 7 and TIA Portal with many extra functionality, like runtime meter, and great faceplates. Basic Process Library for TIA Portal (S7-1200/S7-1500/Runtime Professional) and Basic Process Library for WinCC V7 with example projects and faceplate/S7 block librariesI hope it helps, hdhosseini |
