10/2/2024 7:36 PM | |
Joined: 10/2/2024 Last visit: 10/3/2024 Posts: 1 Rating: (0) |
I need help solving my problem. I have an Atlantic heat pump with an RVS 21.832/127 controller. The controller has a built-in temperature hysteresis between the set temperature and the temperature present in the heating system at 1 degree Celsius. when the temperature drops by 1 degree, the pump starts. Is it possible and how to change it, e.g. to 4 degrees Celsius ------------------------------------------------------------------------------------------ |
Last edited by: Mircio at: 10/02/2024 19:39:46Last edited by: Moderator_Lan at: 10/04/2024 08:12:32New subject after splitting |
