3/2/2020 10:30 AM | |
Posts: 3 Rating: (0) |
hey I have the same problem I checked the cable its ok and I am using the DP9 connector But the RX led are not blinking at all !!! and TX blink what do you think the issue comes from, maybe from ? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/02/2020 14:02:33New subject after splitting |
3/4/2020 3:17 PM | |
Hello thank you I tried to switch the Rx on the Tx but I have thr same problem Tx blink and Rx is not blinking |
3/10/2020 7:28 PM | |
Joined: 4/28/2015 Last visit: 2/7/2024 Posts: 10533 Rating: (819)
Hello, little bit confusing to see different infos but already answered also here to your other question: TX/RX signals on module CM problem |
With best regards... |
