11/30/2007 3:02 PM | |
Posts: 6 Rating: (0) |
Hello, I am using a Micromatic motor with Sinamics S120 and Simotion D435 V4.0. I have a ERN encoder with 2048 periods/rev and 1 sin/cos track per rev. I am not able to configure the SMC 20 module. Whenever i download the configuration to Simotion, my CPU goes in fault mode giving Fault codes F031150, & F31120. While configuring the encoder, i have tried using standard encoder types as wellas i have tried manual entry of encoder data. Still no results. Pls help. AttachmentENC_ERROR_1.zip (625 Downloads) |
12/1/2007 11:07 AM | |
Dear Chris, Regards, Attachmentr0455.zip (591 Downloads) |
12/3/2007 9:50 AM | |
Joined: 5/12/2006 Last visit: 8/5/2024 Posts: 22334 Rating: (3000)
Hello, i have found a data sheet for ERN180 Encoder from Heidenhain, but there are 12 pins. Look on the attached pdf file. Regards Christoph AttachmentMA_ERN_180_Id_Nr_385_514_91_19379.pdf (677 Downloads) |
12/3/2007 11:17 AM | |
Thanksfor the doc, chris we are checking the feasibility of connecting a 6FX cable with this encoder. Regards, Rahul. |
