8/26/2014 7:38 PM | |
Joined: 4/5/2006 Last visit: 8/13/2023 Posts: 642 Rating:
Hello, did it work before or you received a used machine? Can you test it with other (spare) parts? Regards |
8/26/2014 8:48 PM | |
Posts: 6 Rating:
yes i check all node physical address i was found ok.they allwere unique address.three or four time i power up system but still same bus fault on all nodes |
8/26/2014 8:50 PM | |
Posts: 6 Rating:
when i received machine it was in stop mode due to bus fault .and i have no spare im 308 c module .................. Now what can i do???????????????????
8/27/2014 7:43 PM | |
hello, is an EEPROM plugged? Where are you come from? Regards |
8/27/2014 7:59 PM | |
Posts: 6 Rating:
hello yes EPROM already plugged because 2 day ago machine run very well. I am from pakistan
