3/5/2016 9:11 AM | |
Posts: 46 Rating: (1) |
Hi Warning in Line 0 S5 ASCII File: *** FB 240, rel. Addr.0H : Preheader does not exist. *** Warning in Line 0 S5 ASCII File: *** FB 240, rel. Addr.0H : Invalid release (Product No.). *** Warning in Line 0 S5 ASCII File: *** FB 241, rel. Addr.0H : Preheader does not exist. *** Warning in Line 0 S5 ASCII File: *** FB 241, rel. Addr.0H : Invalid release (Product No.). *** Warning in Line 0 S5 ASCII File: *** FB 242, rel. Addr.0H : Preheader does not exist. *** Warning in Line 0 S5 ASCII File: *** FB 242, rel. Addr.0H : Invalid release (Product No.). *** Warning in Line 0 S5 ASCII File: *** FB 243, rel. Addr.0H : Preheader does not exist. *** Warning in Line 0 S5 ASCII File: *** FB 243, rel. Addr.0H : Invalid release (Product No.). *** Warning in Line 0 S5 ASCII File: *** FB 250, rel. Addr.0H : Preheader does not exist. *** Warning in Line 11 S5 ASCII File: *** FB 251, rel. Addr.0H : Preheader does not exist. *** Warning in Line 1337 S5 ASCII File: *** DB 2, rel. Addr.0H : Preheader does not exist. ***
bye... AttachmentTEST02ST.zip (193 Downloads) |
3/5/2016 9:48 AM | |
Posts: 8946 Rating: (999) |
This FB are not supported by S7 any more. Replace them by using S7 commands and / or S7 blocks and system functions. |
3/5/2016 9:56 AM | |
Thanks So do you mean I dont need to put importance for this warnings? And when I compile the attached converted .AWL file in S7 then I found the below errors E Ln 000103 Col 017: No PLC type description found for called or addressed block FC 3. W Ln 000103 Col 017: No valid offline ASCII type description found for called or addressed block FC 3. E Ln 000104 Col 017: No PLC type description found for called or addressed block FC 4. W Ln 000104 Col 017: No valid offline ASCII type description found for called or addressed block FC 4. E Ln 000108 Col 015: No PLC type description found for called or addressed block FC 5. W Ln 000108 Col 015: No valid offline ASCII type description found for called or addressed block FC 5. E Ln 000111 Col 017: No PLC type description found for called or addressed block FC 2. W Ln 000111 Col 017: No valid offline ASCII type description found for called or addressed block FC 2. W Ln 000514 Col 012: Make sure that your global DB is set correctly. W Ln 000519 Col 012: Make sure that your global DB is set correctly. W Ln 000524 Col 012: Make sure that your global DB is set correctly. W Ln 000529 Col 012: Make sure that your global DB is set correctly. W Ln 000534 Col 012: Make sure that your global DB is set correctly. W Ln 000539 Col 012: Make sure that your global DB is set correctly. W Ln 000544 Col 012: Make sure that your global DB is set correctly. W Ln 000549 Col 012: Make sure that your global DB is set correctly. W Ln 000560 Col 012: Make sure that your global DB is set correctly. W Ln 000573 Col 012: Make sure that your global DB is set correctly. W Ln 000578 Col 012: Make sure that your global DB is set correctly. W Ln 000583 Col 012: Make sure that your global DB is set correctly. W Ln 000588 Col 012: Make sure that your global DB is set correctly. W Ln 000593 Col 012: Make sure that your global DB is set correctly. W Ln 000598 Col 012: Make sure that your global DB is set correctly. W Ln 000603 Col 012: Make sure that your global DB is set correctly. W Ln 000608 Col 012: Make sure that your global DB is set correctly. W Ln 000701 Col 012: Make sure that your global DB is set correctly. W Ln 000751 Col 012: Make sure that your global DB is set correctly. W Ln 000796 Col 012: Make sure that your global DB is set correctly. W Ln 000805 Col 012: Make sure that your global DB is set correctly. W Ln 000810 Col 012: Make sure that your global DB is set correctly. W Ln 000815 Col 012: Make sure that your global DB is set correctly. W Ln 001276 Col 012: Make sure that your global DB is set correctly. W Ln 001281 Col 012: Make sure that your global DB is set correctly. Compiler result: 4 Error(s), 29 Warning(s) AttachmentTEST02AC.zip (134 Downloads) |
3/5/2016 11:12 AM | |
Thanks What is the function of FC240, FC241, FC242, FC243, FC250, FC251 of the attached S5 prog.. AttachmentTEST02ST.zip (146 Downloads) |
3/5/2016 2:40 PM | |
What S5 PLC - Type? |
