3/23/2011 1:24 PM | |
Joined: 4/5/2006 Last visit: 8/13/2023 Posts: 642 Rating:
Hello, these are standard blocks. It's not possible to portate it to S7. Check if these blocks are used, if yes then you must find a solution for S7. Regards
André Räppel --------------------------------------------------------------------------------- www.raeppel.de work faster withinnovative PLC-Tools |
3/25/2011 10:37 AM | |
Posts: 63 Rating:
Yes they are a standard block. they are not called in the other function of the program and not used. But i want to know the signification of the ASM 0. thanks |
4/4/2011 5:03 PM | |
Posts: 63 Rating:
OK, thank you very much for your helps |
