7/25/2022 10:33 AM | |
Joined: 4/24/2006 Last visit: 10/8/2024 Posts: 8745 Rating: (1168) |
Hello, You can only use PWM or PTO outputs, when you use Signal boards. See this link: How many drives can you control per S7-1200 controller with the pulse sequence (PTO)? You can not use Relay output. Best regards, Wizard |
