7/15/2020 3:00 PM | |
Joined: 2/22/2016 Last visit: 10/6/2024 Posts: 141 Rating: (30) |
Hi rosario.iameo The modbus library I have written handle unlimited number connection, it will do the connect and disconnect for you. Please check out: https://github.com/rexhip/rexhip Kind regards
Please use the contact form in the link below if you will like to come in contact with me. I don't check personal messages frequently. |
7/16/2020 9:53 AM | |
Joined: 4/28/2015 Last visit: 2/7/2024 Posts: 10533 Rating: (821)
Hello Ola,
very appreciate your work on this problematic, really. Let me say my opinion due big problematic in this area of Modbus. I think users can find your library very useful but on other side (I said this already previously) users then need only support from your side and all can go to situtaion similar with our one other good user Tibi68 and his good Modbus library to CP340/341. In this time users used his library are without support in case of problems and use of his library can be problem. I want say my opinion simply, use of standard Siemens library is better way in my opinion, also many users can help in this Forum with this problematic. I just want say my opinion to all users here, you can select what you want but support then can be problem. Again, this is my opinion due my experience in this area and again apreciate all your work here. |
With best regards... |
