3/28/2013 11:40 AM | |
Posts: 461 Rating: (29) |
Hi, I suggest u to go with webserver concept. In the module properties enable the webserver. First open ur browser & type ur plc IP u can view ur PLC. In that variable tags u can monitor the value. If u need it individually then u have create a user defined webpage & u have to create a HTML script. The following link describes the whole webserver concept with example . /tf/WW/en/Posts/61760 I added my tested HTML code.. configure a word as MyVariable in ur plc tags & modify the value in watch table & check the user defined page the modified value wil be displayed in that field. Hope it helps.. Regards, Nelliyan.G AttachmentWebserver.pdf (73 Downloads) |
