1/11/2023 6:06 PM | |
Joined: 11/21/2018 Last visit: 6/24/2024 Posts: 3 Rating:
Hello, I'm trying to connect my S7-1200 PLC to Mindsphere MQTT Broker without using mindsphere block. I have created certificate into mindsphere and I have create with openSSL a certificate for my agent. If I use MQTTX application this is working I see my asset online in mindsphere. But with my PLC only 80E4 error. I have set the dns, the pls has good date & time. I use same certificate as MQTTX, i have attached some pictures in the pdf file.
Attachmentpictures.pdf (386 Downloads) |
