7/24/2020 12:26 PM | |
Posts: 4 Rating:
Gateway would be 192.168.0.254 |
Posts: 4 Rating:
I don't have this option in TIA Portal V16 |
7/24/2020 3:43 PM | |
Joined: 4/28/2015 Last visit: 2/7/2024 Posts: 10533 Rating:
Hello, you said you have TIA v16. Look to my attachment which shows on S7-1200 which can be helpful. Update: you need be on Offline mode completelly. Use also MOP's screenshot as next help. Update2: looks like you have other problem, maybe IP config conflict so check all devices on network IP to not have same IPs on network. That HMI looks to me strange with that #### loose of connection or not access to PLC. Maybe Proneta can be good tool. AttachmentRouter set example.zip (320 Downloads) |
Last edited by: Duris_I at: 07/24/2020 15:46:09Last edited by: Duris_I at: 07/24/2020 15:47:56Last edited by: Duris_I at: 07/24/2020 16:12:50With best regards... |
