12/19/2017 3:42 PM | |
Joined: 11/16/2016 Last visit: 9/14/2023 Posts: 32 Rating: (5) |
Hi, I use the ''Device States'' block. https://support.industry.siemens.com/cs/ww/en/view/68011497 Topic 5.12.2 You will have to create a boolean array[15] and the identifier will be of the first Profinet I/O device. Using Mode 4, you can check if the Profinet I/O exists or not Attachment68011497_s7-1500_diagnose_doku_v10_en.pd.pdf (70 Downloads) |
Last edited by: Jen_Moderator at: 12/20/2017 8:31:52 AMAdded PDF as an attachment and inserted right link. |
