3/21/2022 4:19 PM | |
Joined: 9/27/2006 Last visit: 7/20/2024 Posts: 12270 Rating:
Hello FM_Merse; O_Einstein is right, confirming your suspicion would be easier if you had access to the PLC's diagnostic buffer. It could be a faulty memory card, but it could also be a problem due to many other causes.. Does your client have a copy of Step 7, of the same version the S7-1515F was programmed in? If so, he can easily open the diagnostic buffer of the CPU, The video below will provide guidance, you can transfer the link to him: https://www.youtube.com/watch?v=nqhT1qi7CR4
Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 03/21/2022 16:21:32Last edited by: dchartier at: 03/21/2022 17:34:49 |
