11/10/2008 10:55 PM | |
Posts: 6 Rating:
Hello Rosa, I have the same problem.After power goes off appears the message "Falta Bloque param". The only solution I have found (until now) is to reload all the PLC program. I also ahve this message when I tried to write initial values to the TD 200 in the main program (Before download it). I'm attaching my program, maybe you can find where is the problem. AttachmentMCHINO_v2.5.zip (89 Downloads) |
