4/10/2014 4:48 PM | |
Joined: 8/19/2013 Last visit: 8/26/2024 Posts: 148 Rating: (11) |
Hello Sarfaz Bhatti, i'm really sorry but these are all technical data you can find on the siemens support page -> https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&nodeid0=10805161&lang=en&siteid=csius&aktprim=0&extranet=standard&viewreg=WW&objid=4000024&treeLang=en or here -> https://eb.automation.siemens.com/goos/WelcomePage.aspx?language=en If you have a special application because you mentioned Ex area you can contact thelocal siemens partner https://www.automation.siemens.com/aspa_app/contactmenu.aspx?ci=yes®id=DEF&lang=en&reduce=prodid517001&comptcID=v Regards |
5/28/2014 8:53 AM | |
Joined: 10/19/2012 Last visit: 4/17/2022 Posts: 315 Rating: (9) |
Pls. see below links for Ex IO modules of S7-300: https://www.automation.siemens.com/mcms/programmable-logic-controller/en/simatic-s7-controller/s7-300/signal-modules/ex-digital-io-modules/pages/default.aspx?HTTPS=REDIR https://www.automation.siemens.com/mcms/programmable-logic-controller/en/simatic-s7-controller/s7-300/signal-modules/ex-analog-io-modules/Pages/Default.aspx |
5/29/2014 2:38 PM | |
Joined: 4/14/2010 Last visit: 8/6/2024 Posts: 525 Rating: (11) |
Dear olloy, many thanks for message, plc hardware will be installed in paint factory. Thanks. |
MS |
