10/21/2011 10:57 AM | |
Joined: 3/21/2006 Last visit: 10/7/2024 Posts: 10229 Rating: (1181) |
You can always call a request to Support Request. In order tomunderstand what is wrong there we can start from the beginning - how this problem has been started? Give us details. Best regards, Hristo Mihalev |
11/3/2011 6:08 PM | |
Posts: 89 Rating: (4) |
Did you check the port in Auto Mode, i.e, CP5611(Auto) or PC Adapter(Auto) and then Start Network Detection. There might be some Baud rate mismatch between the two Partners AttachmentSetPG PC.zip (321 Downloads) |
11/4/2011 1:45 PM | |
Check whether any other device connected in the MPI/Profibus Network with same Address ? If everything is OK , then call Local Siemens Represantative. |
