6/4/2015 7:36 AM | |
Joined: 1/28/2009 Last visit: 5/2/2024 Posts: 6838 Rating: (1359)
If you want to use an H CPU as standalone configuration, you only need to create an S7-400 station and configure the hardware in hw.configuration based on your real hardware installed.In this case, there is no need for the Sync.Modules.Read more in the manual for fault tolerant CPUs. Stand-alone operationI hope this helps, hdhosseini |
